No export from ham2k to email
I’ve worked with some stations and wanted to export the log as usual. But I can’t do that on an Android phone. The version is Android 13.
You need to provide more information. “Not working” isn’t very helpful.
What can I say? I tried to send my log via email. I can select it, but I can’t send it through Gmail, which always worked before the last update. An error message does not appear.
Well now you have at least ruled out an actual export file generation issue, and it’s not a sharing issue. “not working” could have been several other issues.
As far as email attachment sharing is concerned, the mime type has recently been recognised to be causing issues occassionally. This is under test in preparation for the next update.
In the meantime I suggest you share with a cloud service (e.g. dropbox, OneDrive etc) to complete the log transfer to another device/PC.
Thank you and please understand that.. “not working” in the face of many possible things that can go wrong at any time with many steps being involved in the processes, is not a clear statement of your issue.
I’m having the same issue. Google Pixel 10 Pro, updated. Will not export. Clicking the export one file line and nothing happens. Nothing.
Firstly, this is not the same issue. This is a different issue.
When was the last time tapping the → Export 1 selected file action work for you?
It works on other “operations”, but not one that is a general log file (not POTA, SOTA, etc). 86 contacts,
So, literally minutes before and after this one fails.
OK so do you have a location set for the General Operation you are trying to export?
What other differences are there between this gen op and any other op?
I cannot duplicate this on my 3 devices (IOS an Android)
It is a basic operation, I use it for my home logging since my shack is in the barn without a computer. I have my grid square set, and did since I started it. The operation was started just a 2-3 weeks ago. It was started on a Pixel 7, and transferred to the Pixel 10 Pro when the P7 had issues. However, I have another log that was also transferred to the P 10, and it exports.
It is the same setup, from what I can tell, as my other logs.
OK so how did you “transfer” from 7 to 10?
To try and track down the cause - do you have syncing enabled and any other devices in the sync?
Can you also confirm that you have the single file ticked?
The phone has software that automatically moves data. I had to log in to Polo on the new phone, but all of the operations were still there. It is possible I restored it from the Ham2k backup/sync, don’t remember. I do have that option checked.
Yes, I have the single file ticked. If I don’t, the export line says something like select from the export options below.
OK - then can you turn DEV mode on,
then try to export the qson file of the operation
failing that - export the whole databse
I enabled Dev Mode. It would not export when I had both files clicked, but did export when I only had the QSON. I sent it to the help email listed in the app.
On oddity with my particular location is that I am at the very edge of the grid square. My barn is actually bisected by the gridsquare from EM86 ef to EM86ee. My station is in EM86ef, and that is what is listed. However, inside the metal barn, I don’t know what location GPS picksup while logging. I doubt this impacts it, but, thought you should know.
ETA: I used the operation as a template to create another operation as a test. I added two contacts to that, and it would export.
OK thanks - Sebastian will get the email but he is not at his desk atm. You’ll need to wait a little while for more answers.
Allan,
Did you by any chance enable the QWX contest? If so, could you disable it and try the export again?
No, I didn’t have it enabled.
