Template SOTA (nearest) does not set summit
Versuon: Dec 25 Patch 3 Version
Wheel I create a new operation using the template SOTA (nearest), the SOTA summit is not set anymore automatically but needs to be chosen manually. This was working in older versions, but I do not know when it stopped working!
thanks for checking!
73 de OECHD
Thanks for the report. It appears to be a location setting issue.
When you start a new operation, the operation location is not being set even though the device has acquired one. It’s staying unset until after the activities have been assigned.
I’m sure this will be attended to shortly.
Yes. I observed that the location was also not set.
FYI: iPhone 15 pro with iOS 26.2
For me it’s slightly different. If I select a template ,SOTA nearest, it loads a general operation log and then I have to add a SOTA activity. It used to work before the latest update
I am using December 25 patch 4 on IOS ver 18.6.2
