Spot Comment field is locked
Hi Dev team
There’s a defect in the spot comments field in release 25.3.1. Platform IOS 18.3.2 iPhone 13 Pro.
After creating an operation, in my case a SOTA/WWFF/POTA op, when you first attempt a spot, the Comments field appears to be locked with the value of QRV. Touching the field to illuminate the cursor shows the cursor is outside of the invisible text boundary and no matter how much you press the back button the cursor doesn’t move.
After much experimentation I found I was able to remove the extant ‘QRV’ by double tapping on the three characters. Double tapping appears to place the cursor inside the invisible text boundary.
After double tapping I was able to edit my own spot comment.
Andrew VK1AD
Thanks Andrew,
And in android, you ca either tap and hold the back button or tap and hold the QRV text until it is all selected, then type an alternative comment.
This behavior may change in future updates to allow easier replacement of the comment field.
