Splash Screen Issue
The package ‘react-native-splash-screen’ doesn’t seem to be linked. Make sure:
  • You have run ‘pod install’
  • You rebuilt the app after installing the package
  • You are not using Expo Go
Error: The package ‘react-native-splash-screen’ doesn’t seem to be linked. Make sure:
  • at get:1205:476
  • at anonymous:1204:609
  • at Ga:295:78648
  • at vi:295:88160
  • at yi:295:88364
  • at bi:295:88260
  • at yi:295:88348
  • at bi:295:88260
  • at yi:295:88401
  • at bi:295:88260
  • at yi:295:88401
  • at bi:295:88260
  • at yi:295:88348
  • at bi:295:88260
  • at yi:295:88348
  • at bi:295:88260
  • at yi:295:88401
  • at bi:295:88260
  • at yi:295:88401
  • at bi:295:88260
  • at yi:295:88401
  • at bi:295:88260
  • at yi:295:88401
  • at bi:295:88260
  • at yi:295:88348
  • at bi:295:88260
  • at yi:295:88401
  • at bi:295:88260
  • at yi:295:88401
  • at bi:295:88260
  • at yi:295:88401
  • at bi:295:88260
  • at yi:295:88401
  • at bi:295:88260
  • at yi:295:88401
  • at bi:295:88260
  • at yi:295:88348
  • at bi:295:88260
  • at yi:295:88401
  • at bi:295:88260
  • at yi:295:88348
  • at bi:295:88260
  • at yi:295:88348
  • at bi:295:88260
  • at yi:295:88348
  • at bi:295:88260
  • at yi:295:88401
  • at bi:295:88260
  • at yi:295:88401
  • at bi:295:88260
  • at yi:295:88348
  • at bi:295:88260
  • at yi:295:88348
  • at bi:295:88260
  • at yi:295:88348
  • at bi:295:88260
  • at yi:295:88401
  • at bi:295:88260
  • at yi:295:88348
  • at bi:295:88260
  • at yi:295:88401
  • at bi:295:88260
  • at yi:295:88348
  • at bi:295:88260
  • at yi:295:88401
  • at bi:295:88260
  • at yi:295:88401
  • at Nu:295:98237
  • at s:295:97355
Version 25.3.2-discord-2 - Build 25.3.0 (2503911)
Platform iOS 18.3.1 - Apple iPhone16,1 - 409078A7 - TestFlight - unknown
Android the same - of air now.
Can you remind us how to start the app by intercepting the load process?
It has a version revert function no?
OK it just reloaded OK
Yeah, I pushed a broken build to the “bleeding edge” track. Should be fixed now
When the app crashes right after an update, the system should revert to the previous version. But you have to kill the app and start it again.
If you do get to see the splash screen, you can also quickly tap on the “Portable Logger” part of the title (you should start tapping before it appears) and you’ll get an “use in case of emergency” dialog that lets you change update tracks, and backup your database.
OK I need to document that
thanks
Fixed now thanks
