I know there have been a couple iterations of the default comment, but when changing frequencies it used to default to QSY. It’s no longer doing that.
Yes, it was also reported by someone else recently. I’ll try to look into it this weekend.
Not sure if you’re aware but it still says “QRV” in the spot comment box no matter what, even if you change frequencies.
If you just enter QSY in the Callsign box after changing frequency, you will spot with QSY as the comment with one tap on the send.
Oh cool, I’ll have to try it. Thanks Alan
You can QRT as well
QRV, QSY and QRT are all supported.
Which is probably why the bug with the regular spot comment has gone out for so long… I don’t use it anymore ![]()
But I’ll look into it.
