KI2D
1
The October pre-release train has left the station. First stop “pre 0”, which includes:
• Bug fixes for Sync (not yet widely available, sorry)
• Annotations (On the “their call” field, try entering “NOTE”, a space, and then something like “check with spots later”)
• More annotations (try entering “SOLAR” or “WEATHER”)
• Auto self-spotting every 10 minutes (has to be enabled after a regular spot is sent first)
• The usual set of miscellaneous bug fixes
MW7MWZ
2
Hi I’m having issues exporting files in this update (Android 15). Never had issues before - is anyone else having similar problems?
Yes. Same here. Export not working in Oct pre0.
KI2D
4
@MW7MWZ @Kevin_CW_Hiker look in the Play Store for a second update that I released earlier today.
It’s still labeled “pre 0”, but the Base Build should be “25.10.10241” (.10221 is the one with the export bug)
MW7MWZ
5
Perfect! All sorted
. Thank you for the quick response
I can also confirm the Play Store update resolved the export issue.
