Numbers bar, not working properly
When using an iPhone, tapping on the numbers bar requires me to tap on them more than once to have it populate to the call area.
Interesting, my iPhone has no issue - can you tell me the exact build you have atm?
And also tell us what sub features you have enabled for the numbers row.
Alan, my iPhone is the current software 26.1. Current H2K is October 25. Release 6. The settings
Trying to get the same thing occur here. Can you try to turn the keyboard off then on and set comma as I have it to see if things change?
Well as of now it seems to be working.
thanks for the update. I’m sure you will return to this post if it starts to play up again.
