I know I have seen this in a topics, but can’t seem to find it. I just installed the app on a new tablet. What is the best way to have my other POTA logs in the new device? Or this that possible?
Do I need to import in each adif from each activation or make them into one file and import them. If I need to install one file, thoughts on importing my whole log of 5K QSO’s. I would rather just have my POTA contact though.
Long term, a synchronisation service is coming, to allow syncing between devices.
But in the short term if you have a new device, if you enable Developer Mode on your old and new device, you can find option to export your entire database from your old device. Copying this to your new device you can import it, but it will replace the entire database on the new device, so may not be option for you if you’ve already got some activities on the new device.
Atm there is a bug in the file pickup. So importing is broken for some versions. You can when possible import to history which is one file but this has limited value imo.
I tried using the developer mode and importing the file in but it didn’t end up working. But I did merge all of the adif files for pota together and imported that file and it worked. This app is always evolving so I fine something new all the time.
