March '25 - Pre 2
On top of what was already on March Pre 1, we now have:
  • QSO Parties for LA, MO and MS
  • Generic Simple Contest
  • RST input auto-complete on single digit entry (as suggested by HB9BRJ)
  • Fixed exports to GMail and other apps on Android
I’d love for you all to test this last one, about exports on Android. Previously there were many apps that would not accept PoLo exports, including GMail, the Files app, and more. So please test this in as many scenarios as you can if you have an Android device.
How about the FL QSO Party, April 26-27th??
https://floridaqsoparty.org/rules/
Tnx es 73
Ken WB2ART
I plan on having each of the “Parties” ready at least a couple of weeks before their dates.
If you’re tech-savvy you can even help us “write the rules”.
Look at existing ones, like NC for examples, and there’s some documentation about the options
in regards to exporting, Gmail works but seems like Files and Signal don’t. It just closes the “choose app” dialog and goes back to the export page. I can make a screen recording if you need.
Hello,
The exporting to gmail worked fine for me in the past but my problem now is with the time. If i want to input a manual time i just get random numbers appear. The back space and delete buttons just add more numbers. All the other parts work fine when inputting numbers etc, so at the moment i can’t log retrospectively.
The export to Gmail works equally well on my iPhone 13 and the adi files are intact. No issues to report.
Andrew VK1AD
confirmed that… @KI2D will be on to fix this quickly…
In my case, the “Cx Datei Explorer” and the stock “Android E-Mail app” to gmx.ch are working perfect. 73 Roger
I was going to say “don’t put words in my mouth” but I had already fixed the bug by the time I saw this message.
Should be fixed in pre 3, coming out later today.
Alan,
I can also confirm that I get random numbers when inputting sig strength in both tx and rx fields.
Whether I progress using the space bar or whether I tap directly on those fields independently the results are the same.
For example if I input a sig strength of 8, when I move onto the next field I get a random number appear next to the 8, for example 18.
Cheers
Dave
VK6DS
I have the update pre 3 now and time and RT fields all work correctly now in both new and edit existing situations.
I updated and the time field works fine now however the RST fields are still causing the same issue, not every entry however. Seems to start ok, get half a dozen entries in then random extra numbers start appearing. Dave
