The map screen does not show all the information of the operation.
I was working a park that was also WWFF and Bunker on the Air, so a lot of text to display.
The totals of the operation were cut off the screen at the right hand side.
I think the fix is to be less ambitious with your operations
The “Worked Everything, Everywhere, All at Once” Award | Ian Renton so maybe not try this then? ![]()
Which device was this on? I’ve tested on an iPhone 15 and an iPad Mini and cannot reproduce it
iPad 9th gen, iOS 18.1
Going to create a new operation and load logs and see if it does it agin.
Did it again on the iPad when i loaded the logs.
Tried it on my iPhone 13 with same logs and it loads ok.
Tried it also on my old iPad Pro 10.5 inch and it does the same at cutting the text off.
Are the ipads where it fails models with a physical “home” button?
I have a suspicion that this is related with how we allow for some space for the virtual navigation elements around the screen, notches, etc.
Yes they are!
The map from yesterday’s POTA activation doesn’t show my location. Did I do something wrong? Thanks, Glenn KC1EIJ
if you go back to the operation, and in the “operation” tab, tap “Location”… what do you see there?
Thank you, that did it. It was a grid number instead of the park. I selected the park and it’s all set
