Log times corrupted
I’ve used POLO over a dozen times without issues until today. From a POTA operation from 1600 to 1900 UTC, today, I noticed chunks of my log were out of chronological order when I got home. It wasn’t like they were uniformly shifted by the same amount. The log times differed between 13 and 42 minutes from the actual entry times. Another oddity, about half of the log times showed 00 seconds (HH:MM:00), and the rest were all at exactly 31 seconds into the minute (HH:MM:31). I was able to reconstruct the correct times, but there is something strange going on. I did update the app a few days prior. de WB2HOC
You may have at one time adjusted the time of one QSO.. in which case you need to tap the time… you will see a button “Back to Now”.. which brings your timer back to running in current time.
Accidentally typing a time adjustment shortcut can produce this result.
Tapping back now Resets
