I currently have 120 activation operations on my old iPad. Sync to the LoFi Cloud is running.
If I upgrade my iPad, will I my operations be copied by the Apple transfer facility or will I be able to restore my operations to the new device?
ATM the sync is only one way. So your data is protected.
But the only way to move data to another device is using the Developer Mode “Backup entire database” on the old device and then “Replace Ddatabase” method on the new device.
Many thanks Alan
At least it can be done
Update: New iPad setup using previous iPad as data/app source.
Polo did not get copied across, Test Flight did.
Reinstalled PoLo through Test Flight no drama, exported PoLo database from old iPad to cloud and then installed onto new iPad no real drama.
The only thing that needed setting was QRZ and HamQTH accounts.
Lost my Ham2K 2025 supporter badge - no drama
Activated a UKBOTA yesterday with no problems
Thanks for the feedback. Pretty sure the badge will return.
No problem Alan, I probably need to stand the team another coffee!
You can get the badge back by clicking on the “contribute more” button and then looking for the “restore” link somewhere in the bottom of the screen.
Many thanks Sebastián
Alas, I get ‘Error 8: The receipt is no valid’
No dramas, I’ll just buy you another coffee
I’ll take the coffee ![]()
But I’ll also see if I can fix it.
Hi Sebastián,
I sorted the issue by ordering more coffee and Apple restored my badge instead!
I’ll get you another coffee though
