Dissappearing menu in QSO list
So I created a test log to get accustomed to POLO should I want to do my first POTA on Aug 6th and found something oddly interesting while in the QSO list. When tapping the 3 dots in the top right, the menu appears. Tapping off the list makes the menu disappear. When tapping on the dots again, the menu flashes, then it never returns until backing out of QDOs and re-entering.
Including a link to the video to show it in action.
https://youtube.com/shorts/StlzS6g-ZMk?feature=shared
The device used is a Samsung Galaxy S20 Ultra running Android 13
Thanks - and instead of tapping the hamburger button a second time, what happens if you select an option to turn it ON/OFF, then select the hamburger menu again? Does it flash on and off in this case?
I’m sure this will be fixed shortly, thanks for the post. And the work around is good for the moment.
Just gave it a test. When selecting any option, the menu functions normally. I’ve only noticed the issue when selecting a blank white space to close the menu.
Thanks for the update
This should be fixed in the September release
