PoLo is now available in Spanish, French, German, Norwegian, Slovak, Dutch! More languages coming soon (stop by our Discord chat if you want to help translate)
World Castles Awards
SOTA 2026 Challenge
Operation location now includes optional State and County fields
What activities/App Features do you have selected and active in the App Features list?
If you have them all, it would help to turn them all off and then add them back to see which on might causing this issue. Perhaps the newly added World Castles?
you’ve added the SOTA 2026 Challenge to the app. What exactly does this mean? I haven’t found any settings, or activation function in the app. Is it just a definition for the exported ADIV file?
Thank you so much for this great logging app and the perfect support.
If your operation includes SOTA, and you are on the 2m or 70cm band, and you’re in SSB or CW modes, then the “grid” field shows up.
We’re also now including any POTA or WWFF references you might have hunted, as these are also used by the POTA program to determine the distance of your QSOs.
I’m loving the County and City ability, especially for overseas contacts. I did find a problem though. Supposing I log a contact from Wales, England. I can edit the QSO to include his name and city. I notice that this information is remembered by the app so it will automatically appear in future QSO’s with the same station. This is all GOOD. The only issue I see is that the app doesn’t look backwards in my log and update 𝒑𝒓𝒆𝒗𝒊𝒐𝒖𝒔 QSO’s I have had with that station.
One other issue is that some callsigns that have wider letters are getting cut off as per below screenshot from my iPhone 15 Pro Max
I’m afraid there’s only so much room on a mobile device, especially in portrait. You can turn it to landscape, even momentarily to get wider columns. Many people use tablets for this reason.
But you can also tap an entry to view it in Edit mode and see all the detail at any time,
As far as editing pas QSOs’ is concerned, no this is not done.
You can open previous operations and do a Lookup All in the operation hamburger menu if the lookup data what you want.
