Dec 7 & Dec 8 logs…
I had two activations on 7 December 25. The first was accepted by ParksOnTheAir with no problems. The second was rejected, because I must have listed it as 8 December 25. The QSOs were in the 2300 UTC hour, so should still have been 7 December.
Is there a way to edit the ADIF or would it be easier to create a new ADIF? Using POLO it is easy to edit an individual record. I am hoping there would be a similar way to edit the date of the ADIF from 8 to 7 December.
Thank you.
vy 73 de David AE4LH
I’m not sure what you mean by “the date of the ADIF”.
All the QSOs are date and time stamped for the QSO. It’s the QSO date that is meaningful to the POTA upload, not the file date. The ADIF file date is not relevant.
But I’m not sure what you are referring to.
If you have a log/operation which contains QSOs on 2 days one after the other - crossing UTC. POTA will split the log into 2 separate activations.
Is this what you are missing? The single upload will end up in POTA as 2 activations
I have the dates and times on the same day, but the latter activation was given the next day. I must have entered something wrongly. I’ll just reload the file. Thank you.
OK, you might need to be aware of the Post Logging feaure,
Sometimes OPs triigger a manual date time and don’t realise they need to set “Back to Now” to continue.
