I can confirm that since December pre0, any attempt at entering a gridsquare will crash PoLo.
If I add a park and let the park establish a grid, it will remain but if I try to then edit this gridsquare, PoLo also crashes out.
I fix for this was committed recently, so should be in next pre release soon.
@M1SDH Steve does this fix the issue when you spot yourself the grid is removed?
Don’t know. I can test to see later today.
I have had this happen also. I went back to using the November build until it gets fixed in the next update.
Should be fixed in the latest December pre releases
