Add SiOTA spots support via ParksnPeaks (by M1SDH)
Add Canadian Historical Sites on the Air (by M1SDH)
The most important is that we seem to have fixed the problem that was causing crashes on a good number of Samsung and Lenovo tablets and phones. If you had to install the “Lite” version of PoLo, it’s time to try the regular version again.
I figured out how to activate it. And I am using it. i am expecting, that user feedback from early adopters would be helpful for the development, if this is the case, I would like to provide such - knowing that it is an experimental feature. But I woule like to know:
a) is this actually already helpful?
b) how should I provide such feedback? I did not want to open a new thread without having asked.
I hope this clearifies my question a little bit better.
OK - no, there is no need to do anything unless you discover something that is not working as expected.
Obviously this is not a forum for Wavelog. They have their own forum. So matters which pertain to how Wavelog is working should be taken there.
But if e.g. you found the sending of QSOs not to work when it should, then raise it here.
Thank you team! This app goes from strength to strength. Really appreciate all the work that goes into such a comprehensive tool. Used on over 60 SOTA Activations in 2025.
