POTA log don’t export
I can’t get the log to export with the latest beta update
Latest March non-beta has just come out. I’m not sure if there are any fixes for anything related to this to be honest, but worth a test.
Can you not export any log at all? Or only to certain apps?
Just that log so far. It was small so I’ll recreate it.
Mike Hausauer
K7CAN
I can export the older logs but any new ones I create doesn’t allow for export. Also on the latest iOS edition not including Apple beta.
Question, did you have any activities added to this operation that you didin’t use?
I did not.
I can duplicate the issue when I create a new log. The old ones have no issues exporting
Can you give me the exact steps your following, so I can try to reproduce this locally?
FWIW: I’m having the same issue. Just did an activation and same result. Can’t export this log, but the last one I did on the 11th exports fine.
iPad Air (4th gen); iPadOS 18.3.1; PoLo 25.3.0
13 QSOs: 9 US, 4 DX
Operation activities: POTA + WWFF
Trying to export the POTA and WWFF logs. Both are checked (Full ADIF is not). Tapping “Export 2 selected files”: the command row highlights but nothing happens. (Also tried combinations of one log, all logs; switched “use compact file names” off and on).
Going to a previous log and things work as expected - I can export POTA+WWFF logs from previous activation.
Tried force-quitting app and relaunching: data is still there but no change.
Just pushed 25.3.1 which should address this. Check for updates inside the app.
Latest updated fixed the export issue. Thanks team!!
Mike Hausauer
K7CAN
You got it working again Boss Man!! Thank you and the Dev Team for a quick fix!!
Mike Hausauer
K7CAN
Apologies for the brief inconvenience.
73 de KI2D
