Is anyone having problems uploading adif log to the pota website that has more than 1 park in the a tovation?
If you are activating a 2fer or 3fer… PoLo exports a separate log for each park. You need to uoad each of them separately. Is this what you mean?
That is what i mean. But for some reason it is not separating the logs for me. Nor is it seprating when a ham throws two or more parks. It keepshas 1 log or 1 contact.
If YOU are in a 2fer you must add both parks to the activation. If you work someone else in a 2fer you MUST add both THEIR park references to the QSO for 2 contacts to be generated.
Yes, I have done both. And done both in the past. And in the past it haswork no problems. I am not sure what is different. I have the new update, and for the moment I have to add separate logs n qso’s.
Is this YOU working a 2fer or working someone else in a 2fer?
Hi Alan. Apparrently my last reply was too short, lol. The answer is both. I was at a 2fer and then I had parks to parks hunter that was in a 2 fer. The upload only put 1 park. I ask for support from the park on the airs people and their suggestion was to make a new log with all the info as single contact, up load that log and it will merge with the “master” log, which work, so that is was i have been doing.
For example. Saturday was I us-2856 & us-9568. I exported the adif file and then uploaded to park on the air. In the past it would upload both park great and on the website it would show 2 separate parks. Now it polo app is only showing 1 park in the adif, and if i make a contact with a ham with multiple parks, it is only showing 1. I have to go back in and make a separate contact and manually add the time:different park number n signal reports of the contact. Also I have to my activations where I have 2 parks myself, take out the park that the adif saved and just leave the 2nd park number by itself, save it, export it and then upload that 2nd log to parks of the air. I have never had to all that before. I have not done anything different, so I dont know it i messed up a setting or something change in an update. Then next time I am at a 2fer park I will attempted to screen record my set up to email.
If you are activating a 2fer you select both parks. PoLo will then create separate logs, one for each. But you must use the POTA exports not the “full” export to upload to POTA.
The full log has only single versions of your QSOs. But the POTA logs has all the additional QSOs.
Alsn
HAAAA I bet that is where I am missing the piece to the puzzle, I will try that next time, Alan, thank you for the patience and working through this.
On the Manage Exports page, make sure you have all 3 logs selected (ticked), then export the 3 logs, then use the POTA version for upload. The full version is for YOUR own logging system.
Willdo. So far I got all upload, the very long way but upload.
