This has been requested by several people, and it’s something we’re working on.
It will be a button in the Operation Data screen, where you currently can export ADIF files and such, that would directly export the log QSOs to QRZ.com using their XML Logbook APIs.
I don’t know if it’s a limitation of additional log books created within QRZ.com, but I can’t seem to export /P operations created in PoLo to QRZ via ADIF.
Use case: create new logbook for SOTA activations in another country, e.g. EA8/KI2D/P. When you save that new logbook in QRZ it will show the operator as EA8/KI2D, and any PoLo logs you export as EA8/KI2D/P will throw an error on QRZ import due to owner callsign mismatch.
I’m not trying to hijack the thread, just adding some weight behind the need for a direct export-to-QRZ feature. More than happy to help with testing etc.
Thanks for the response, @VK1AO and @KI2D. On my last export from this morning’s SOTA outing I used station callsign EA8/G5MUP and operator callsign EA8/G5MUP/P, and that imported into QRZ.com without issue. But I’m not sure if that’s going to cause problems later on because a lot of SOTA operators always log /P - think it’s mandatory in some regions - and I don’t know how strict QRZ.com is when it comes to lining up confirmations.
Not necessarily, because people have holiday homes where their shack isn’t portable, and they may have a certain level of pedantry forced upon them by local legislation. OFCOM (in Great Britain) dropped the need for /P and also for secondary regional identifier (I can be GD5MUP or G5MUP when I’m at home in Isle of Man) but I understand France is still quite strict on that sort of thing, and when I operate in France as F/G5MUP then I must use /P when portable.
